Can't Log Data After Upgrade
dyip
Post by dyip »
I am running App V1.12 and Firmware 2.13. Everything seemed to work fine after upgrading including CAN messaging, reading analog variables etc., but I cannot log any data. I have used the new Automatic Control, Lua Scripting, and pushing the Action button to try to start logging.
No error messages just no logging. If I enable SD logging in the app, then exit the app, SD logging is shown as being off the next time I enter the app.
I have tried a new SD card but it did not help. Not 100% sure if this is related to the firmware/software upgrade, but nothing else has changed since we last used the datalogger in the fall.
When you activate logging via one of those means (e.g. button) do you see the SD card logging LEDs flashing on the font panel? Does the red error LED light up as well?
Try ensuring you don't have a lua script in place that attempts to control logging; a script could override the behaviors, causing conflicts with what you're trying to do manually.
Also, ensure you're on the latest 2.13.5 release, not the beta 2.13.0.
Let us know what you find out. Thanks!
