Interfase with Adaptronic
microcar
Post by microcar »
Has anyone used a RaceCapture/Track with an Adaptronic Module ECU?
Hi, if the ECU has a published CAN bus interface, it should be able to work with RaceCapture/Track's CAN mapping tools. Got a lead on the ECU's documentation from the manufacturer so we can review?
microcar
Post by microcar »
Brent, I sent you an email with some Adaptronic files attached to see if you can help. Thanks.
Thanks - the files we received don't have any CAN protocol information. Contact the ECU mfg and they should be happy to provide this information!
Let's keep the conversation here so others can benefit from the results.
microcar
Post by microcar »
I tried to attach the CAN protocol for my Adaptronic eMod016 Modular plug-in for a 1999 Miata. Hope you can figure out how to interface your RaceCapture/Track with my Adaptronic. Your system will not let me add the file as an attachment. Says it won't allow word files and when converted to PDF, says is too large. I will send it to you by email. Thanks
microcar
Post by microcar »
Brent, I am sending the attachment by email with some additional information on Adaptronic CAN that you may be able to use.
Moving to CAN mapping discussion.
microcar
Interface with Adaptronic ECU
Post by microcar »
[quote="brentp"]Moving to CAN mapping discussion.[/quote]
Any success in interfacing using CAN to an Adaptronic ECU using all the information I provided? Would really like to be able to use Race Capture Track, that sure is a great product.
