Wifi and Bluetooth not connecting MK3
Hi Tim,
Thanks. We're actually making progress.
RaceCapture generates an internal log, and we need that log to see what it's doing when it's trying to initialize WiFi.
We have some instructions here to get the log. Could you go through the steps and copy/paste the log here as a reply?
Instructions: https://wiki.autosportlabs.com/RaceCapt ... apture_Log
Thank you,
Thank you,
OK. I got the log. the MK3 wouldn't log into my desktop. Ill worry about that later.
*** Start! ***
[watchdog] Initializing...
sizeof LoggerConfig: 10296
[CAN device] Initializing CAN0 with baud rate 1000000
[CAN device] CAN init success!
[CAN device] Initializing CAN1 with baud rate 500000
IMU: init res=0
GPS: Initializing...
[OBD2] Init current values
BT: Detecting baud rate...
BT: Baudrate: 115200
[lua] Initializing Lua state
[lua] memory usage: 16KB
[lua] Starting Lua Task
[wifi] Initializing...
[lua] Loading script. Length: 0
GPS: provisioning attempt
BT: Device responds at baud 115200
BT: Init complete
[USB] Starting telem stream on USB
GPS: Using baud rate: 115200
GPS: module detected at: 115200
GPS: detected current update rate: 10
GPS: Configuring NMEA messages
GPS: Message was successfully received.
GPS: Successfully configured NMEA
GPS: configure navigation data message interval: win
GPS: Configuring Gnss Navigation Mode: win
GPS: Disabling NMEA messages
GPS: Successfully disabled NMEA messages
GPS: provisioned
[ESP8266 Driver] Failed to probe WiFi device
[ESP8266 Driver] Init failed
[wifi] Initialization failed!
[main] Setup Task complete!
[USB] Stopping telem stream on USB
*** Start! ***
IMU: init res=0
BT: Init complete
GPS: provisioned
in looking at the system status for WiFi, it is now showing access Point is disabled again. I also noticed when carrying the MK3 to my office, that I hear a light clunking inside, like something is loose. Is that normal, or is this a concern? I figure it might have something to do with the accelerometor system, but not sure. In Wireless settings, both WiFi Module and Access point are still showing on.
I'm having exactly the same problem. I have a RCP MK3. It has worked fine for the last few months, but I now cannot see it to connect on either wifi or bluetooth from any device.
I followed the advice on this thread. I updated the firmware to 2.14.0. In the app on my Mac I go to Setup -> Wireless and bluetooth and wireless are both on. I have turned on and off, read/write/power cycle etc. But when I go to System Status -> WiFi I see access point "Disabled". No combination of read/write/power cycle seems to change this.
I pulled the log, which looks like same issue the OP is having here.
*** Start! ***
[CAN device] Initializing CAN0 with baud rate 500000
IMU: init res=0
[lua] Loading script. Length: 21
BT: Init complete
GPS: provisioned
I'm at the track (Sepang in Malaysia) and racing in about 18 hours from now, so quick fixes appreciated!!
*** Start! ***
IMU: init res=0
BT: Init complete
GPS: provisioned
