Directry CAN mapping for Podium
i am using Podium with AIM SOLO & SOLO2.
Unfortunatery , i can see only limited CAN signal along SmartyCom Stream.
i want to see other signal that CAN mapping.
If possible , could you tell me how to setting (hard & soft)?
Hello,
Our RaceCapture and PodiumConnect system has a 2nd CAN bus which can be used for other purposes.
The first CAN bus connects to the primary CAN network for AIM, and then the 2nd CAN bus can be used to talk to other CAN bus networks, such as ECU or other sensors.
We have information here on how to map CAN data on the 2nd CAN bus.
Hope this helps!
Hope this helps!
You do not need to write any Lua code for mapping CAN channels - simply use the easy UI for defining channels. We have it documented here: https://wiki.autosportlabs.com/CAN_Bus_ ... o_channels
Thank you,
Thank you,
CAN mapping except 1 or 2 byte
Hello Brentp-san,
i could directly see CAN mapping data for 1 or 2 length(1(8bit) or 2(16bit) byte).
i want to see except 1 or 2 length.
For example 1 bit type and 12 bit type.
You can see attached file.
Could you tell me how to set them?
- 1bit pattern , 12 bit pattern
- CAN_Mapping1.PNG (47.93 KiB) Viewed 27205 times
See the Bit mode note in the CAN mapping documentation here:
https://wiki.autosportlabs.com/CAN_Bus_ ... he_mapping
You will be able to map a channel with values < 8 bits that way.
Let us know how it works!
Hello Ferg-san,
Thank you for quickly reply.
Actually , i try to other vehicle.
i attached 2 mapping. One was done, other is not....
i think this case can ignor little endian and big endian.
In this case i could see signal.
- Succeed_1bit.PNG (8.97 KiB) Viewed 27160 times
- Succeed_1bit_RCP.PNG (18.93 KiB) Viewed 27160 times
