I have a Track Mk2. It seems to work great for HPDEs / circuits with the tracks from the library.
However, I’m trying to figure out how to get the track configured for autocross.
Unfortunately, I cannot exactly drive the car to the start and finish lines before a run (though I’m tempted to try and see how quickly I get a DQ), so using the mk2’s GPS is not going to work.
Is there anyway I could use my phone (iPhone)’s GPS to configure the course? I could happily do that during the course walkthrough. The only other thing that comes to mind is to connect a 12V battery to the device and carry it and the GPS antenna around with me, then reinstall it in the car. That is not an ideal solution.
Suggestions?
Autocross start & finish lines
Hi -
If you can't pre-drive the course to set the points, what you can do is manually set a stat/finish line for the system by first getting the coordinates using a separate GPS app, and then programming it into the system as separate start/finish points.
https://www.youtube.com/watch?v=4Wr6N50 ... 5j&index=2
It is pretty clunky, but we are looking to improve it.
Here's the other way you could create it:
https://www.youtube.com/watch?v=ekTP0x- ... j&index=11
Let us know how that works. Thanks!
