![Smile :-)](./images/smilies/icon_smile.gif)
Anyone know of something I can put inline to map Miata Fuel tank Level back ?
Here's the Miata Fuel Sensor specs and research from a few forums..
Gauge 110 ohm adjustable fuel converter
Looks like 12V
Gauge is 110-0 ohm fuel sender (Mazda Miata)
Engine Running vs. Not can change Ohm's (there's a calibration), you can check on your voltmeter.
Full: 3 ohms
3/4: 15.8 ohms
1/2: 32.5 ohms
1/4: 64.2 ohms
E: 110 ohms
notes:
i believe the fuel sender is a variable resistor, so the signal to the gauge in the cluster is a resistance value, something in the neighborhood of 0 to 90 or 100 ohms. I think there is a tap out on the back of the cluster where you can read the voltage from the gauge, but if you remove the cluster you wont have it.
