Hello ,
i set up Podium what my friend get.
Then i try to use it.
Unfortunatery it could not correctly work.
i saw everytime CAN red lamp turn on.
So, i try to install latest farmware .
i install all.
But could not resolve.
Is it behavior from hardwear issue?
Please resolve this . We could not use it.
Podium Hardware CAN Warning lamp turn on
Hello ,
gentlly reminder.
Even though i introduced podium to shop.
But this one did not correctly work.
We use podium with AIM solo DL.
If use this one , GPS had 3min delay. Then CAN signal value was not correct.
Therefore i tried to change to my podium what it had good result .
CAN red warning lamp turned off. And All signal had correctly working.
(Off course my podium can correctly work.)
What meaning CAN lamp was red colour ? Was hardware broken?
gentlly reminder.
If you are not getting CAN data from your AIM system, please check the CAN baud rate under Setup / CAN bus. ensure it is set to 1MB so it communicates correctly.
The CAN led is orange, and flashes when there is communication.
You can also run through the first time setup, which will automatically set all of the parameters for the PodiumConnect system:
https://www.youtube.com/watch?v=KlDTo4PnYuA
Just select the PodiumConnect preset.
Thank you,
Thank you,
Hello,
The orange CAN light is not a warning, but indicates that the unit is receiving CAN data, so that is good.
You can perform a diagnostic that the unit is receiving data by doing a basic CAN logging script, which shows all data being received by the system. You can find instructions here:
https://wiki.autosportlabs.com/CAN_Bus_logger
If you see data arriving in the window, then you know the unit is receiving data.
Please, let us know what you find out.
Thank you,
Thank you,
