How can we send an HTTP POST request to connected WiFi client via Lua Script?
So if I want to say use Chrome extension SERVISTATE to send commands to a WiFi client via POST request, how do we do it?
Here's another example of what it looks like:
https://forums.garmin.com/apps-software ... reless-api
@brentp this is all it takes to Start and Stop recording of Garmin Virb. Oh so close.....
[Solved] How to send HTTP POST request via Lua Script?
- startRecording.JPG (113.94 KiB) Viewed 14373 times
To do this you'd have to turn off WiFi (so RCP isn't trying to control it) and then issue direct AT commands to the WiFi module in RC.
See the bottom of the page here:
https://wiki.autosportlabs.com/AutomaticCameraControl
The WiFi module is an ESP8266, so you'll be able to find information on the web on how to perform HTTP POST commands.
Boo ya, got it!
to start recording:
to stop recording:
Turns out, the Virb is picky about character indents at the start of each subsequent line. I had followed some examples found by Googling "esp8266 http post request at command" and had an extra space between \r\n and start of next line. I saw this with the println command, but didn't realize this makes a difference. Took out that space and voila, it works!
Now to skinny up the code since the Garmin API syntax is the same up to the command. According to API, this can be "status" "startRecording" "stopRecording" etc.
to start recording:
function startRecording()
sendAt('AT+CIPSTART="TCP","192.168.0.1",80')
sleep(2000)
local crlf = string.char(13) ..string.char(10)
local post = 'POST /virb HTTP/1.1\r\nHost: 192.168.0.1\r\nAccept: */*\r\nContent-Length: 28\r\nContent-Type: application/x-www-form-urlencoded\r\n\r\n{"command":"stopRecording"}\r\n' ..crlf ..crlf
sendAt('AT+CIPSEND=' ..toInt(#post))
sleep(1500)
sendRaw(post)
println(post)
sleep(5000)
sendAt('AT+CIPCLOSE')
end
sleep(2000)
sleep(1500)
sendRaw(post)
println(post)
sleep(5000)
end
That's great. Would you be interested in updating our wiki docs with this information?
If so, we'll open up wiki access to allow you to edit. email sales@autosportlabs.com to coordinate.
Sure, happy to contribute and update the Wiki.
Meanwhile, here's some more info on the POST command.
The Postman program was super helpful to figuring this out. The easy part is simply sending the command via the Postman command line.
What was really helpful was using the Postman feature to view the "code"
Then as @brentp suggested, I Googled "esp8266 http post request at command" Careful with the results, because some of them pertain to GET command, not POST command. (For reference, GET is what the GoPro Hero uses.)
These were the two most helpful hits for me to get this figured out.
https://stackoverflow.com/questions/406 ... an-esp8266
After getting the above fixed command to work I came up with this more generic POST function.
It works by passing the required arguments to the postCommand function, e.g.:
or
The Virb didn't seem to care if the command length was correct or not. e.g.
{"command":"startRecording"} is 28 characters, and
{"command":"stopRecording"} is 27 characters.
This corresponds to the Content-Length: value
But I kept this in there in case it matters for other devices. So now you can have fun trying this out to send info to other WiFi connected devices.
function postCommand(cmd)
sleep(500)
local post = 'POST /virb HTTP/1.1\r\nHost: 192.168.0.1\r\nAccept: */*\r\nContent-Length: ' ..toInt(#cmd)..'\r\nContent-Type: application/x-www-form-urlencoded\r\n\r\n' ..cmd ..'\r\n' ..crlf ..crlf
sleep(100)
sendRaw(post)
println(post)
sleep(100)
end
postCommand('{"command":"startRecording"}')
postCommand('{"command":"stopRecording"}')
- Garmin Virb startRecording command via Postman
- startRecording-command.PNG (15.58 KiB) Viewed 14357 times
- Garmin Virb startRecording HTTP code via Postman
- startRecording-code.PNG (17.09 KiB) Viewed 14357 times
