[Solved] Help with Brake script on wiki
Moderators: JeffC, stieg
Canyonfive
Post by Canyonfive »
Here is my script. Where did I go wrong or why did it stop on the MaxDecel?
MaxDecelG = 1.20
chBrake = addChannel("vBrake", 25, 0, 0, 100, ' ')
function updatevBrake()
BrakeG = getChannel(LongAccel)
BrakePos = (BrakeG/MaxDecelG)*100
if BrakePos < 10 then BrakePos = 0 end
BrakePos = math.abs(BrakePos)
if BrakePos > 99 then BrakePos = 100 end
setChannel(chBrake, BrakePos)
end
setTickRate(25)
function onTick()
updatevBrake()
end
Here is the error
[lua] Script error: [string "MaxDecelG = 1.20..."]:5.0: Expected number or string argument at position 1
[lua] Failure: Runtime Error
[lua] Gracefully stopping Lua Task
[lua] Destroying Lua State
[lua] Initializing Lua state
[lua] memory usage: 17KB
[lua] Starting Lua Task
[lua] Loading script. Length: 354
timebase/logging/telemetry sample rate: 100/100/50
Canyonfive
Thought it might be the uppercase in the variables but no it still fails
Canyonfive
Even though I'm on the current firmware it looks like it worked with getImu instead of getChannel.
MaxDecelG = 1.20
BrakeG = getImu(1)
end
setTickRate(25)
function onTick()
updatevBrake()
end
