Unit no longer powering up when connected via OBII
hardware installation for the RaceCapture Plug & Play, including custom installations
Add186
Post by Add186 »
I have a racecapture/track mk2 that was working great however this past weekend seems was no longer receiving power from the obdII connection. Powers on fine from the usb connection. My obdII reader receives power and not sure what the issue is. Any help appreciated.
Canyonfive
Re: Unit no longer powering up when connected via OBII
Post by Canyonfive »
Add186 wrote: Thu Oct 08, 2020 8:11 pm I have a racecapture/track mk2 that was working great however this past weekend seems was no longer receiving power from the obdII connection. Powers on fine from the usb connection. My obdII reader receives power and not sure what the issue is. Any help appreciated.
Have you ohm'd out the power line in the OBD cable to check for continuity to make sure you dont have a problem with the cable?
