Screen Flashing
KMRACING
Screen Flashing
Post by KMRACING »
Hello I recently purchased the Race Capture Pro and finally got the gauges needed for track. We where at the track this past weekend for the first time with the product and the data would display but seemed to flash at the driver consistent while on track which made it hard to read. Is there a fix for this
Re: Screen Flashing
Hi, thanks for posting. Can you post a video that illustrates this flashing, or describe it in more detail?
The RaceCapture is designed to flash the lap time on the screen whenever you pass the start/finish point, but I'm not sure if you're referring to this.
KMRACING
Re: Screen Flashing
Post by KMRACING »
I've tried to upload a video with no luck, but with what I have been told is there a way to fix the sensitivity with the program because of the flashing I can email a video if needed thank you
Re: Screen Flashing
A photo of the dash design or video is fine. you can email sales@autosportlabs.com if that helps.
Note, that under some conditions if you put a line chart on the dashboard, it might cause flickering / flashing. If this is the case, try removing the line chart.
