edis Module and heatsink
boostedmini
Post by boostedmini »
Hi Guys,
not sure if it true, but i recall reading somewhere that i need to use a heatsink on the edis module.
is this true? do i need to use one?
thanks all.
Grant
T3tone
Heat sink
Post by T3tone »
Im not sure weather its needed or not but i mounted mine on a piece of alloy thats slightly larger than the module and spaced the alloy plate away from the inner wing where its mounted so pretty simple anyway.
I haven't seen information
I haven't seen information on this subject. Anedoctal evidence shows that you need minimal to no heat sinking- On my test bench I had one mounted to a piece of wood running for hours on end, it only became slightly warm.
I would imagine if the bracket it came with is mounted in such a way that it made as much metal-metal contact with the chassis as Ford did with the OEM installation it should be fine- this way any heat generated is transferred into the body of the car.
boostedmini
Thanks guys,
I am prob going to put it on the inner guard of my mini so it should be ok i hope but a small bit of alloy would be ok too.
p.s like the new site guys
Grant
dan
Post by dan »
i also heard that heat could be a problem with the edis module so i put a pc heatsink on the back of mine:
and then attached it to the inner wing of my mini spacing it away from the wing so that air can circulate:
maybe a bit overkill, but better safe than sorry ;)
Dan :)
Gilesy998
Post by Gilesy998 »
As above, it might be a little overkill, but I liberated a heatsink from work and clamped it between the EDIS and bulkhead - I even stuck some thermal transfer compound between them, just in case :lol:
boostedmini
Good Job, I like it, I will see how mine goes and let you know.
grant
That is very pretty (and functional). What did you use to secure it to the EDIS housing?
dan
Post by dan »
i used ordinary superglue; however i have been wondering how well the heat will transfer through it in to the heatsink, so i may remove it and re-attach it with something with good heat transfer abilities.
DannyP
Post by DannyP »
Maybe JB weld?
KLAS
Post by KLAS »
just look at computers. there is a heat sinking glue to put heat sinks where no clip exists to holt it, from Arctic Silver i think
DannyP
Post by DannyP »
