Installed no probs on ford crossflow (x-flow)
As it says, installed no problems.
Made up a bracket to hold the VR sensor, got a toothed wheel on the front of the pulley, made up my own loom no problems.
Using a TPS on the twin weber 40 dcoes - works a treat.
Need to wire up a shift light now, and get my rev counter working. I have tried to use pin 11 off the EDIS, no joy - have also tried the tach out line on the MJ with no joy - next to try the diode circuit.
Now to start tuning the map!
Cheers
Will.
Cheers
Will.
got any pics!!!
Hi will , well done.I'm just about to start wiring mine to my 1700 x-flow.Have you got any photos of your installation , particuly the vr bracket.Where did you source the tps from .Hope you can help , many thanks Bryan
xflow install
Hi Bryan
I will try to get some pics sorted and uploaded to a site somewhere. The VR bracket was quite straight forward really, as you will see.
I got the TPS from emerald (www.emeraldm3d.com) and it included the carb spindle adaptor, but you can get the TPS from RS Components for about 16 quid too if you'd prefer.
Will.
Will.
Pics!!
Hi Will.If posting your pics is a problem you can email them to me at bryan@brmorum.f2s.com. The emerald tps is a good price , i'll order one of those as its another thing i wont have to make.thanks Bryan
TPS
I too am installing the MJLJ on a Xflow, I sourced a TPS from a Zetec Mondeo in the scrapyard, I think it cost £1 (GBP).
I have also been working on a map, although not yet tested, I would be happy to swap this with other Xflow tuners.
My Xflow spec is 1660cc, Lightened and Balanced, Race Head, Piper 285 cam, Twin 40's. One of the reasons I am installing the MJLJ is to try an eliminate some pinking at certain RPM's.
How did you attach the Trigger Wheel to the Pulley, I sourced a wheel from a Sierra, and need to weld it to my Pulley, but need to get a steel pulley first, does anyone have one spare?
Doug
Doug
TPS
I'm assuming you chaps are running twin carbs? If so then a TPS from a Mondeo will do the trick as will cost a couple of quid. It's just a case of fabricating a bracket and spindle like this:
http://www.cate1.co.uk/megajolt/installation.php
(see bottom of the page)
The Mondeo one is virtually identical to the Webcon one except for the wiring with is opposite.
I've got a number of maps on my site for Pintos, Zetecs and a Vauxhall one but if you need someone to host Xflow maps, I'd be more than happy.
regards
Matt Dearden
(2lt Pinto Cat)
regards
Matt Dearden
(2lt Pinto Cat)
Maps
Hi Matt
Yep, using twin carbs..
I've got a 150hp xflow map (based on a kent 244 cammed engine with forged pistons) and that will be my starting point to get it right for my 135hp engine (kent 234 cam with hepolite pistons 10.5:1 CR)
I'm more than happy to share maps too - Matt if your happy to host, perhaps we can start a bit of an archive! If you don't mind, I'll post your website details on the Westfield forum as a great source for anyone considering the upgrade...
Will.
Will.
feel free to upload your igni
feel free to upload your ignition configurations under the 'files' section above- to add files go to the 'create content' page- link on upper right.
Brent
Brent
Trouble uploading
Hi Brent,
I've tried a couple of times to upload the map I'm currently using along with a link to all the others but keep getting an error:
"You exceeded the maximum submission rate. Please wait a few minutes and try again."
any ideas?
cheers
Matt Dearden
(2lt Pinto Cat)
any ideas?
cheers
Matt Dearden
(2lt Pinto Cat)
Cheers
Happy to host any map you might have. I'm trying to build up an archive (as you can probably tell!).
I really think Megajolt's the perfect solution for us kit-car builders as it's so much cheaper than any of the "off the shelf" ones you can buy and you can build it yourself. Please feel free to spread the word!
cheers
Matt Dearden
(2lt Pinto Cat)
cheers
Matt Dearden
(2lt Pinto Cat)
Hi Matt I was wondering if
Hi Matt
I was wondering if you'd sorted out some crossflow maps to go with yor collection. Over this next week or so i hope to finish my install on a 1640cc crossflow in a mk2 escort. The engine is rally spec and if you had any maps, i would be grateful if you could email me them.
sharpknuckles@hotmail.com
Simon
Simon
1st proper run out
Hi All
A quick update for you all - I have just had a quick run out in the car (30 mins or so) and it was really fabulous. I think my tinkering with the carb jetting has helped too, but there is now very little (if any) spitting / banging on the overrun and the whole car now appears more responsive across the whole rev range.
I am sure a bit more fine tuning on the map will help even more, but I am really pleased with the progress so far.
Thanks all
Will.
Thanks all
Will.
map for xflow with 244 cams
Hi
I have a kent 244 cammed Xflow engine with forged pistons.
Any one got a map that they would share with me?
/jano
jan@janolesen.com
/jano
jan@janolesen.com
