Hi there,
Does anybody know of a uk source for the brass bulkhead hose connectors and vacuum pipe needed if using the map option?
Cheers,
John
Uk source for vacuum pipe bulkhead connector and vauum hose?
Pipe is easy - any autopart
Pipe is easy - any autopart store, about 40p/metre
Not sure about the connector. You have three choices, obvious pros and cons between each one:
- don't use one - take the pipe straight to the sensor. Need some strain relief at the sensor though
- make one - or get a mate with a lathe to make one in a few minutes - just cut the head off a M8 bolt, turn down at each end to slightly bigger than the inside diameter of the pipe and drill through the middle
- keep looking(!)
- keep looking(!)
