MLJT 0.2.2.1260_preview +++FINAL+++ Released
4600cc
Post by 4600cc »
Megajolt Lite Jr Tuner version 0.2.2.1260_preview is out!!!!
New in this version:
* Removed time restrictions.
* Fully functional PRESS SPACE TO MARK.
- TO MARK, while in RD, click on PRESS SPACE TO MARK button, or press a spacebar, or press an ENTER, or press a SHIFT key. A marking will be displayed in the Mark List window in the following format. Accel_TYPE, RPM_BIN{RPM_VAL}, MAP_BIN{MAP_VAL}, IGN_ADVANCE. Example: N, 1{2000}, 1{50}, 10....and that would be Normal acceleration, bins 1/1 rpm/map, 2000 rpm, 50 map, 10 degrees advance.
<hr>
<b>* YOU CAN LOAD THE ORIGINAL MEGAJOLT MAPS (*.cfg). If you folks did not know (I don't judge), MLJT was able to load the original megajolt maps, the ones made in java software, from the very outset. Just go to File > Import > From CFG file, similarly you can save a CFG file by going to File > Export > To CFG file.</b>
<hr>
Known issues:
* In mark list RPM_VAL is not displayed. Function is there to convert between ticks and rpm, and vice versa, just needs time. This is for the full version.
To download look under 10 most recent files section for:
mjtuner_0.2.2.1260_preview-Installer.exe
adist-mjtuner_0.2.2.1260_preview-a.zip.zip
Those two files are Installer and Archive distributions. Installer was created using the latest and gratest NSIS version, so now it should work on Windows 95, 98, ME. Use Archive dist if the installer don't work.
Have fun! Do not break your local traffic laws! Read the license before downloading.
Alex
