Just found this site
<a href=http://www.charm.net/~mchaney/roaddyno/dyno.htm>Road Dyno</a>
U suply it info from your car like weight,gear ratio's,friction loses,temp,humidity,barometric presure,elivation
and it work out dyno values
can't we write program to analise csv log an give something similar ?
or mayby just an excel sheet ?
Thanks Conrad
Calculating engine power via RPM acelaration ?
Hi Conrad,
That's a very interesting idea. A spreadsheet would be the quickest route- I believe all of the data is there in the log, you would just need to add information regarding mass, gearing / diameter of driving wheels, etc. Apply some standard Newtonian physics and you should have reasonably close numbers.
Any volunteers?
Any volunteers?
