Tried it with the relays and it works just fine on the test bench - can't get much simpler that 2 relays attached directly to the REV LIMIT output and 2 10R 10W resistors.
I'll draw some qualitative pics of what I saw with my 'scope on the coil -ve terminal later, with and without the resistors in place and link to them here - they're quite interesting...
I'm liking this a lot so far!
Just need a car to try it on (don't have a MJLJ'ed car since I sold it 3 weeks ago - but I extracted the MJLJ before it went) to ensure that there's no unexpected side effects
I'm confident that the solution kills any coil charging in progress without causing a spark, so maybe our originally perceived problem of premature sparks has been solved...?
Hard rev limit
I'll stick with David's
I'll stick with David's original thyristor rev limiter circuit. Why? Well, because you (only you) had a problem with it. AND, because you just let me know today you don't know how to open a file.
I don't find your argument, that David's circuit does not work, credible. As a matter of fact this raises the question, why would David post a non-functional circuit of a hard-cut rev limiter? It is more likely that the circuit is a little complex and hard to trouble shoot, and lacks sufficient documentation.
