Options switch resistor...
- Contact:
I am fine with electronics when there are two wires - if they spark they are the wrong way round! However, as I have found out, the PCB doesn't like sparks and such-like so I am trying to avoid doing that again...
Could someone please tell me exactly what part number (from Maplin would be handy) I need to buy for the dual mapping switch?
Can it be wrapped in heat-shrink tubing to avoid any shorts, or what is the recommended method if not?
Thankyou for any help!
Land Rover 1957 S1 88" 2.5 petrol/LPG
If you are wiring up the switch as in http://www.autosportlabs.net/MJLJ_V3_ve ... tion_guide then you need a SPDT (single pole double throw) switch
If you want small then Maplin part FH98G, if you want big then Maplin part JK27E
- Contact:
Thanks MartinM, I already have the larger of those switches.
It was the way I worded it but what I meant (without actually managing to say it!) was the resistor - what part number for the resistor...
Maplins have various different types and wattages of resistor and I don't know the differences!
- Contact:
Thanks. Hopefully thats all the building questions out of the way!
I am getting excited now - got the vacuum tubing last night and wrapped all the wiring - just need to feed it all round the engine and through the bulkhead somewhere! There is a small light at the end of the tunnel...
Let's hope it's not the light from a far-away very large train heading straight towards you...I'm sure it won't be though
It's recommended to put a "U-shape" in the pipe below the level of the MJLJ has a vapour/liquid catcher - sounds a good idea but quite what happens if you actually get some liquid in the "U" I'm not sure....
If you have a MAP MJLJ then the alternative to putting the resistor physically on the switch, and to simplify the wiring, is to:
- put it on the circuit board in the position that L1 normally fits in
- connect Molex pins 4 and 6 together in your wiring harness
- use a SPST switch to earth/not earth the join of pins 4 and 6
![Very Happy :D](./images/smilies/icon_biggrin.gif)
- Contact:
Yes it is MAP setup.
From looking at the assembly instruction pictures, is L1 on the TPS part of the board nearest the molex connector just beside the Zener? (Looks like the L got drilled through!)
Just trying to work this out in my head now! When the switch goes to earth, does this stop the resistor from doing anything therefore the controller sees no voltage and switches maps?
So I could use any on/off switch, and this would go to earth when 'on' - for example ON(earth) - OFF(nowhere!).use a SPST switch to earth/not earth the join of pins 4 and 6
Exactly there....yes, the "L" is drilled through
With the switch OFF, the pin 4/6 join is held at a high level (5 volts) by the resistor - so one of the maps is used
With the switch ON, the pin 4/6 join is held at a low level (0 volts) since it is directly connected to earth via the switch - so the other map is used
Time for you to get experimenting![Very Happy :D](./images/smilies/icon_biggrin.gif)
![Cool 8)](./images/smilies/icon_cool.gif)
- Contact:
Good, that's now wired in! Should be test running it at Astle Park show tomorrow!
As I don't have a laptop to plug in while in the vehicle, and my PC is in the attic at home, how do I load dual maps with the megajolt unplugged from the vehicle?
For testing/map changing purposes, I have a 9V battery to plug in to + & -, do I then have a wire from pins 4&6 back to the - as well via a switch?
- Contact:
Sound like you are measuring between the battery +ve and the pin 4/6 join? - you should be measuring between the pin 4/6 join and battery -ve/earth ...also don't measure either side of the resistor - just the "outbound" side ie the pin 6 side.
So...you should be measuring:
+5v between pin 4/6 and battery -ve/earth with the switch open
0v between pin 4/6 and battery -ve/earth with the switch closed
- Contact:
