Windows Vista Problems
Ive had two problems with Windows vista and v3.2.1. 1) I can't open any maps, computer freezes and I have to hard boot to get out of it. 2)Using a belkin FSU109 USB adapter (with vista driver), I can get an initial reading then it won't communicate with the unit at all. I know the unit is working because I can run it on my XP pro desktop with the serial connection. Has anyone else used the unit with the belkin USB adapter and Vista?
- Contact:
Hello,
The configuration app itself was developed on Windows Vista, and should work fine. Your symptoms (computer locking up hard) lead me to think the problem is happening inside the device driver for the usb->serial adapter.
- Have you tried a different USB->Serial adapter, such as the prolific model? Just as a test.
- Could you point me to the Vista driver you used for the belkin adapter? I may have the same adapter in my vast collection of different adapters, so I'd like to double-check on my end.
- Are you using the same usb->serial adapter on your XP machine?
i have a similar problem, program will load and periodically get updates. have the same adaptor and running vista, will work with other software, (aeb gas computer running serial) i have attached the driver i was using, and was using 3.2.0 config software
Cheers
Ben
Cheers
Ben
- Driver.zip
- (19.85 KiB) Downloaded 1621 times
make and model is stated above and i will try in on my old xp based machine and see if the driver makes any difference, belkin does only suggest that it is a pda adaptor but it seems to work fine with other serial based devices like my leonardo LPG computer.
http://www.belkin.com/support/product/? ... 109&scid=1
