m having real difficulty! version 3.0.0 board trying to upgrade so i have tps calibration and interpolation across the sites. but i cannot get the firmware to the mjlj .comport ok i can read whats on the mjlj with the old configurator ok .new config 3.2.1 in ok, its just the firmware ive followed the steps this is what i get in the black box
C:\Documents and Settings\lee>\-------------what here---------
ive cut and pasted the what here of the forum help page and followed the instuctions ie mjlj off and then power on but never got that far !!
Hope this makes sence lee.
firmware update problem
Hi Lee,
It seems in your message that the latest 3.2.1 configuration software is currently working with your controller?
Try checking the controller firmware version by clicking Help/About in the configuration software. (make sure the MJLJ is connected and powered on)
I'm suspecting you might already have the latest 3.2.1 firmware!
Hi Brent,
Version 3.0.0 configuration software is currently working with my controller. I do not have tps calibration and the other new functions.
the curcuit board 3.0.0 with tps
When i had the latest configuation software it would work untill i powered up the mjlj , then a box came up on the screen telling me what firmware i needed i.e. 3.2.1 ,we have tried but could not change to the latest 3.2.1 firmware! im sure it would work if i had a clue.
YOU ARE OUR LAST HOPE OB1 KONOBI. use the force.
thanks lee
thanks lee
Very well.
How far along the upgrade guide ( http://www.autosportlabs.net/3.2.x/2.8. ... rade_guide ) did you get until you had a problem?
After you issue the command to upgrade the firmware, what is the response you see? What error messages are being reported, if any?
Are you using a USB-Serial adapter?
screen shot
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\lee>"C:\Documents and Settings\lee\Desktop\Films\hc08s
prg.exe"
usage: hc08sprg port[:][S|D|?] [speed] file
port:D ... dual wire mode (default)
port:S ... single wire mode
port:? ... detect single/dual wire mode
speed ... speed in kbps
file ... S19 file
Any ideas , im using the cable i got with the mjlj, also burnt it to disc and got the same message Lee
prg.exe"
file ... S19 file
Hi Lee,
Be sure to follow the instructions carefully, starting from the beginning of the upgrade guide. (linked in my previous post)
In the 4th step (here: http://www.autosportlabs.net/V3.2.x_/_2 ... ware_image ) it calls for you to issue the upgrade with the correct COM port and name of upgrade file.
Give that a go and let us know how far you get.
Yippee
We have a result , when i downloaded the files i stored them in the wrong place. once that was corrected we had no problem (computers and me not a good combination) thanks very much for all the help. lee
firmware update
I did not link the files that was the problem , when you are computer iliterate like me the easy things are hard to do !!! learning all the time. lee
