Map switch question.
rally2
Post by rally2 »
What are the electrical requirements when using one of the switchable outputs? Can it handle 12v? Is it grounding only? When will pigs fly?
PS I like the new site Brent.
vw16vt
outputs
Post by vw16vt »
The output are high/low ground/open circuit, so it's a ground, not a voltage. And use relay to turn on whatever you want.
Math
Luca Lagonigro
You can drain 800mA from the
Post by Luca Lagonigro »
You can drain 800mA from the 2N2222A.
Yep- you should be able to dr
Yep- you should be able to drive a relay with no problems. It switches ground, so the other side of the relay will connect to +12v.
