New user here, about to do an install on an old Mini. Does anyone know the OD of the ford trigger wheel PN F2LE-12A227-BC, its pictured here:
http://megasquirt.sourceforge.net/extra ... 227-BC.jpg
Any other dimensions would be nice as well, I believe it is used on the Modular V8, but it's behind the timing cover so I haven't been able to see one in the junkyard. Thanks,
Ford Trigger Wheel Dimensions - F2LE-12A227-BC
Scott Flanagan
-72 Mini 1275
-66 E-type 4.2L
-72 Mini 1275
-66 E-type 4.2L
I am holding one in my hand here. The outside diameter from peak of tooth to peak of tooth is 126mm. The inside diameter is 32mm. They hide these on the inside of the timing cover on 5.4L engines, I think the 4.6L is the same. I'm a Ford/jaguar tech so I just had to check my junk drawer to find one. Oh, they are CHEAP new from Ford.
