Fuel and megajolt
supercharger_1500
Fuel and megajolt
Post by supercharger_1500 »
Hmm did I cock up big time here? I think MegaJolt can control the fuel injectors.
Now I'm thinking I got it all wrong...!
david jenkins
Post by david jenkins »
You're not getting confused with Megasquirt are you?
That's a full ECU for ignition, fuel injectors, etc. More expensive, FAR more complicated!
supercharger_1500
Yes I am mate, So say I replace the carb for fuel injectors then can MS work with MJ ?
Yes, Megajolt can feed a tach signal to the Megasquirt. This is how we're running our turbocharged MR2.
Megasquirt can also handle ignition via firmware and hardware modifications- However, I don't have experience with that.
MartinM
Post by MartinM »
The clue is in the names...
Jolt = spark = ouch!
Squirt = fuel = burn!
I'd completely agree with Brent about the MS firmware and hardware mods to make it do sparks - they are significantly complex...
supercharger_1500
Thank you guys, I'm still some off getting the engine to run. I'll need to look into this and come back. Running carbs at the moment.
cheers
