Trigger wheel
luke6040
Trigger wheel
Post by luke6040 »
Hey i was just wondering if anyone has got some good dimentions of a trigger wheel that has been used on a mini.
Any help would be great thanks.
Luke
KLAS
Post by KLAS »
mine is same OD as the damper and the teeth are about 1mm thick
luke6040
Post by luke6040 »
cool that looks nice do u know the internal diameter? and how have you fixed that on(weld, bolt?)?
Thanks for your time,
Luke
KLAS
Post by KLAS »
sorry, don't know the ID, enough to clear the chain housing
it's bolted to the 3 small holes you have when you remove the stamped metal part from the back of the pulley
its made out of a Ford Sierra pulley, lathed to fit exactly to the Mini pulley
fitted it looks like this
mr_bridger
Post by mr_bridger »
i got my trigger wheel (ring gear style) from www.trigger-wheels.com and got my pulley machined to suit it with the dimensions of the pulley i received. similar to this:-
mj-001.pdf
(38.1 KiB) Downloaded 1120 times
luke6040
Post by luke6040 »
where it says 92h6 is that the internal diameter ? so its 92 mm
sorry about all this.
mr_bridger
the one i bought was the 5.125" with 4" hole, so the bit that says 92h6 i got machined to a tad under 4", and the depth about 4.5mm so that the seated ring gear was a touch proud of the pulley. this gave me something to clamp down onto with my m3 screws.
luke6040
Post by luke6040 »
i have started looking at fitting the pulley, so i sorted the pulley out from my box and i think its the wrong type is there 2 types of pulley on the mini?
KLAS
Post by KLAS »
yes there are more than one. the most common one are a pressed steel one, used with small bore engines and one with a thick damper, used with 1300ccm engines.
luke6040
Post by luke6040 »
oki iv got the pressed one, how do you go about fitting the wheel to this as there are no flat sides?
thanks for your help.
KLAS
Post by KLAS »
i've done this once, just welded it to the outer edge of the pulley and removed a lot of material from the inside.
my blank triggerwheels centers at the middle of the pulley, the part that fits the crankshaft, don't know how its called.
sorry, didn't have pics
luke6040
Post by luke6040 »
iv just spoke to an ebay man and he can get me a cast 1 for £15 would this be easier?
KLAS
Post by KLAS »
yes, you can use screws to fit the trigger wheel
luke6040
Post by luke6040 »
sounds like the new plan then thanks
mr_bridger
here are a few pics of my wheel...
first get the pulley machined, needs to be a nice fit, and the recess slightly shallower than the wheel thickness (i had mine done 4.5mm, and wheel is 5mm)
Then drill and tap 4 holes to clamp the ring.
IMG3 (Medium).JPG (55.75 KiB) Viewed 13203 times
IMG2 (Small).JPG (75.3 KiB) Viewed 13204 times
IMG1 (Medium).JPG (59.33 KiB) Viewed 13205 times
