TPS load bins
Dimbit
TPS load bins
Post by Dimbit »
I can't find any clarification on this so thought I'd ask:
When running a tps should the load bins stop at 100 or still go on to 255? Does 100% tps correspond to load=255 or load=100? I downloaded the standard pinto map and am wondering why the bins go up to 152. Should I just normalise to 100 and call it done?
Yes, TPS load axis is 0-100%. That file might've been a TPS map that was made prior to the 3.2.x firmware. I'd recommend normalizing it as you suggested.
