Tach very bouncy!!
miniboo
Tach very bouncy!!
Post by miniboo »
I have connected up my rev counter to the output from megajolt.
It works but it is very bounucy and also when coming off the throttle it tends to zero then go back to normal or if i am on part throttlewit goes to zero.
Should i be using a different method to run the tach?
It is an old smiths tach i think.
910esprit
Post by 910esprit »
I have the same problem on Smiths Tacho Read WHOOPS thread.
I am going to try the fly back method as this is how the Tacho was driven in the origional installation.
I will post if it works.
advantage998
Post by advantage998 »
Its weird mine only does it when the advance is higher than about 32 degrees.
Why would this be?
________
weed vaporizers
The pulse-width of the tach output varies with ignition advance since it piggy-backs on the SAW pulse emitted from the controller. Some tachs, like yours, won't see the signal if the pulse-width is too narrow. In these cases you'll want to use one of the alternative methods for driving your tachometer.
Paul f
Post by Paul f »
I am running a Smiths tacho using the pip signal.I had a problem with the diode circuit due to the zener breaking down and causing a missfire , so I tried the pip signal and it works perfectly.
Paul
910esprit wrote:I have the same problem on Smiths Tacho Read WHOOPS thread.
910esprit
Post by 910esprit »
I have tried the fly back method and the tacho works up to 2000rpm then drops to 0.
removing the Zenner diode causes the tacho to stop working.
Removing one of the diodes and the tacho works but as you would expect only shows half the reading.
are there any down sides in using the pip signal?
The PIP should be fine even if it's driving the tach and the MJLJ PIP input. Just verify the MJLJ can read RPM in a stable way- stare at the screen for a while, or just do a datalogging session. If you're satisfied then you should be good for a permanent fix!
910esprit
Post by 910esprit »
Success! :D
Wire Tacho to pip signal and very stable and responsive tacho and MJ tacho readings stable.
Thanks for the Help another Happy MJ user.
miniboo
Post by miniboo »
so i can just tap into the PIP signal? think i need to read the wiki again
