V4 Software/Firmware updates
Information and announcements on updates to the Megajolt firmware and PC software
Hello all,
We'll have an update to the V4 config software which will address a variety of minor issues. We're also looking into adding a couple of features:
1- generating an auxiliary calibration table based mapping a few points from a temperature sensor or other device
2- Rolling in the firmware programming capability into the config software, rather than relying on the rather obtuse hc08sprg.exe software
These two may or may not make it into the bugfix release.
We will also be releasing a V4.0.2 firmware which addresses an intermittent problem where the configuration software may complain about 'invalid data' after flashing the controller memory (either Ignition Config, Global Config, or aux/load calibration data).
We should have these updates out by tomorrow evening.
luke6040
Post by luke6040 »
will these updates include the firmware for the V3 board.
Here you go: V4.0.2 firmware and V4.0.1 configuration software can be found here:
http://www.autosportlabs.net/MJLJ_V4_Downloads
This update is for V4 controllers only.
For the configuration software, the two new features listed will be rolled in with the upcoming feature update for the V3 configuration software - and corresponding firmware.
