slow software
slow software
It takes an age for the software to start up and sometimes freezes, i'm running windows XP anything i can try to speed it up?
Paul
Paul
Hello Paul,
Can you provide the specifications of the machine you are running- Processor, memory, free hard drive space? if you don't know, list the manufacturer and model of the PC.
What version of the Configuration software are you using?
Are you using a USB-Serial adapter, or a regular serial port?
Is it slow in general, or just on a particular function, like the 3D tuning view?
If you bring up the software with the MJLJ disconnected (and any USB-Serial adapter unplugged from your machine...)-- does it improve, worsen or stay the same?
Also, please bring up task manager while the software is running, and click on the "processes" tab. Sort by CPU usage, high->low. What applications show the highest CPU usage?
celeron 1.3ghzbrentp wrote:Hello Paul,
10gig free
1g/b memory
version 4.0.0
using the usb serial adapter
its slow to load(2mins), once loaded its fine.
its the same when disconnected
when i bring up task manager and click on the processes tgab i dont have an option for "sort by cpu usage? all the applications are showing zero usage? might not be doing what you asked properly though.
Paul
See the attached- sort CPU usage from high to low, this puts the apps consuming the most CPU at the top of the list.
So far hard to say why it's running slow on your machine. Do you have another machine, with similar capabilities you can try it on?
Do all of your other apps run fast enough?
I'm actually surprised to see that others are running so well on such slow machines- I guess that's good!
Paul, only as a test, could you download the 3.2.1 configuration software and run it by itself to see if it makes any difference?
Finally, when you say "disconnected" you actually mean the USB-Serial adapter was *unplugged* from your machine? this is important.
- task_man_screen_cap.png (53.29 KiB) Viewed 35808 times
All my other apps run fine, ive got another mini that runs complete fuel and ignition on DTA and this runs fine.
Where can i download the older version from i can only fine 4.0.1 newer version?
Nothing is connected (serial was unplugged) to the laptop when i try the software.
Ive tried the task manager thing again Brent and the configuarator is way down the list.
Ive run the sortware on my desktop which is only slightly better than the laptop and it loads quickly. Looks like its my laptop
Its a Dell inspiron 2200 if anyone else has any problems.
Thanks for the help so far
Paul
Paul
Oh- download the 3.2.1 here:
http://www.autosportlabs.net/MJLJ_V3_Downloads
Just install, test and uninstall. It won't interfere with your 4.0.0 installation.
Also, there's a 4.0.1 SW version you should install while you're at it.
If the slowdown is coming from the UI-redrawing you might consider looking for an updated driver for your graphics chipset.
You can also try running the software after booting up in windows "safe mode", this runs windows in a 'leaner' mode with a default VGA graphics drivers, in addition to not loading a number of other background services.
I started it in safe mode and the software loaded straight away. I then had a look at the graphics adapter and tried to update it. I am using the latest one apparently
I noticed that i had 2 of the same graphics drivers loaded but no conflicts so i uninstalled one of them and rebooted the software now loads as all the other software does
Thanks for all of your help, i'm glad its sorted.
Paul
Paul
