Whats the best way to do this?,begin the map at 0 or -4 degrees?.
Can I in fact do this?.
Standard specs call for the ignition to begin advancing at 0-4 BTDC and at 600RPM.This a picture of the standard ignition curve.
or 1.33 Kpa? Thanks guys I'll give it a go and see how we run!910esprit wrote:1 mm Hg - 133 PaRon B. wrote:Mine is a V3 ,but i have it starting OK with 0 advance at 500RPM. In the pic i posted the right hand graph is the vacuum graph for a standard engine. How could i go about translating that into the load bins ? In the pic the vacuum is expressed in mm of mercury. Cheers!
