Posted: Thu Aug 30, 2007 3:45 pm
Your computer must have multiple COM ports installed. Perhaps one is the serial port on the back of the case, and the other is the internal modem? In either case, the hc08sprg.exe will attempt to use either one.
Only when the hc08sprg.exe program gets the signal from the MJLJ processor will it proceed with the flash programming.
To see which COM ports are installed on your computer, go into Device Manager and expand the 'Ports' section. There you'll see the installed ports on your computer.
If you're able to determine which COM port you have your MJLJ plugged into then use that one.
Be certain of which COM port you need to use before attempting the firmware upgrade- otherwise you'll just be frustrated.
Backing up just a little bit- I'm assuming you were able to communicate with the MJLJ before you started the firmware upgrade attempt?
For the upgrade process I trust you're following these steps? http://www.autosportlabs.net/V3.2.x_/_2 ... ware_image
It is super important you follow the required power cycling sequence-
1. no power to the MJLJ
2. issue the upgrade command
3. after seeing the 'waiting for hc08... ' message - apply power to the MJLJ
4. you should see the programming software spring to life.
So report back!
So report back!
