Iv had a look about the forum and you guys definatly seem like you know your stuff.
Now my project is slightly different to other ones and i havent seen it done yet (let me know if you have).
I have a Ford Fiesta Zetec S with a Ford Puma 1.7 VVT engine in it. To add to that i have put a set of twin carbs on it. I used twin 45 DCOEs as I owned some at the time, these are currently being down jetted and down choked to the same as 40 DCOEs.
I also have an MJ running this set up using the TPS off an old escort.
Iv had alot of problems with this car and constant misfiring and flat spots. Im not skilled enough to set it up myself and it doesnt help when i do not have a rev counter to go through on the MJ software (to help setting up obviously).
This is where i pleed for help hehe. Basically i need help find out where to get a rev counter sensor from or how to make one work?
Also does anyone have any ignition maps that may be close to this setup?
What size jets and chokes do you think i should down grade to?
Should i upgrade my firmware from V3 3.0.0 to V3 3.2.1 ??
Can i get VVT on the puma engine working with the MJ or do i need an OMEX 200?
I would appreciate all the help i can get as this project has been going on too long.
Thanks in advance
Paul
