Page 2 of 2
Posted: Sat Apr 22, 2017 4:03 pm
That crystal should work!
C1 correct?
Posted: Tue Jan 23, 2018 12:34 am
by GTIspirit
Is C1 the correct form factor? Looks a bit small for the pads.... Can I solder the one end to the circle? Or does the circle not connect to the pad just to the right? Build list calls for "SMC_D" package. Somehow I bought "SMD/SMT."
Does it matter if it's polarized or not?
I finally got around to working on this.... This is some tough soldering! It's extremely difficult with a very fine tip soldering iron and magnifying glass. I thought I had pretty steady hands and good eyes for fine work, but this is near my limit.....
Posted: Tue Jan 23, 2018 12:38 am
Good job so far!
You need a SMC D sized package for the capacitor, and it is polarized. It's a tantalum capacitor, and the polarity matches the band orientation on the PCB. Capacitance isn't critical; 15uF to 33uF should be fine.
Posted: Sat Jan 27, 2018 2:14 pm
by GTIspirit
Components aren't mounted as straight as I'd like, but they should be functional..... I learned a lot from soldering the first board. That's why I ordered three PCB, because ordering 3 from OSHpark didn't really cost any more and gives me a few for practice.
brentp wrote:GTIspirit wrote:
* CPOL-USSMCD doesn't lead directly to a "polarized capacitor." Searching for a 10uF "polarized capacitor" yields results for bi-polar/non-polar and general purpose. Which is correct?
you can use a 10uF 1206 ceramic capacitor, 16v. Polarized capacitor not required.
This is what I ordered for 1206 10uF "C1"
1206YD106KAT2A
1206 is too small, will
1812 size work?
Mouser doesn't list a "SMC D" package, what is the equivalent case code?
The pads look smaller than x 0.12" so maybe "case code" 1808 is the right size? Except no product is available with capacitance 10uF - 33uF with that case code.
Looking at capacitance range 10uF - 33uF the nearest "case code" is 1812, which is slightly bigger than the pads in the one direction. (If L1 is 1812, 1812 looks a bit big for C1.)
Does polarized matter, or not?
Is there is a recommended C1 capacitor at Mouser.com?
Posted: Sat Jan 27, 2018 6:04 pm
These are the correct capacitors:
https://www.ebay.com/sch/i.html?_osacat ... d&_sacat=0
https://www.mouser.com/Search/Refine.as ... d+case+smd
Narrow your search for a 10-33uF variant, it's not a critical value.
Good luck!
Posted: Mon Nov 18, 2019 9:27 pm
by Billy C
Sorry to revive a dead thread...
Is the circuit board layout and BOM still available for the canx? The Github link only has firmware in it.
I have an original Race Capture Pro MK1 and would like to start using the can features on it but never
purchased the can board when I got the Race Capture.
If the canx info isn't available anymore, can I use the OBDii adapter for the RCP MK2 and just use the CAN pins from the OBDII plug?
Posted: Thu Nov 28, 2019 8:20 pm
by Billy C
Bump,
Anyone have these files still?
Posted: Fri Dec 06, 2019 6:09 pm
The CANx project for MK1 was actually renamed; it is here:
https://github.com/autosportlabs/RaceCapturePro_MK1_CAN
We recycled the CANx name to represent a general purpose mini CAN development board, not related to RaceCapture/Pro MK1 at all.
Sorry for the confusion, and we hope this helps!
Posted: Fri Dec 13, 2019 5:42 pm
by Billy C
Thanks Brent,
I have a friend helping me put a few of these together.
Is there a recommended enclosure for it?
Posted: Tue Dec 17, 2019 7:49 pm
Thanks for the follow up. Sorry, we don't have a recommended enclosure.
Posted: Fri Jan 10, 2020 11:51 pm
by Billy C
I ended up using the hammond 1551HFLBK. With a little bit of trimming it fits like a glove. I can't take the credit for all of this though. A friend helped out with this project.
I'll see if I can embed the pics from google.
Posted: Sun Jan 12, 2020 5:07 am
by Billy C
So I got everything plugged in but the MK1 software doesn't seem to have a tab for mapping. Is there something I'm missing here?
Posted: Fri Jan 17, 2020 1:36 am
by Billy C
I can't seem to get the RCP to even initialize the can module. Is there some other step I need to do here?
Posted: Thu Feb 13, 2020 9:53 pm
The MK1 firmware doesn't have direct CAN mapping in the firmware, but you should be able to use the Lua scripting to send and receive CAN messages.
https://wiki.autosportlabs.com/CAN_Bus_ ... _scripting
