'88 SAAB turbo application?? (newbe)
Posted: Sun Feb 04, 2007 6:08 am
I am using the Bosch FI and Ignition from a '88 SAAB turbo on my Lancia 2L with a Volumex super charger.
It does a fairly good job but I am having to eliminate the dizzy due to a clearance problem.
With the bosch system , it uses the pickup in the dizzy to signal both the ignition and the FI system.
Can the EDIS and megajolt supply the required signal to fire the FI system if the stock dizzy/pickup are removed??
Second...if it will work should I use the TPS or Map sensor set up?
Third...will it work with a knock sensor??
I had looked in the Q&A history but most post were fairly old pertaining to this set up.
Thsnks!
Thsnks!
