READ ME FIRST: Posting Ignition Configuration Files
Please use the following format when posting your ignition configurations. Easiest is to copy/past the following block of text:
Engine Mfg:
Engine Code:
Cylinders:
Displacement (cc):
Rev Limit:
TPS or MAP:
Boosted or Normally Aspirated:
If Boosted- max Pressure (KPa):
Modifications:
Chassis:
Notes:
Example:
Engine Mfg: Toyota
Engine Code: 4AG
Cylinders: 4
Displacement (cc): 1600
Rev Limit: 7600
TPS or MAP: MAP
Boosted or Normally Aspirated: Boosted
If Boosted- max Pressure (KPa): 255
Modifications: 14b Mitsu Turbo, Crower turbo cams, TRD valve springs, light intake porting, TVIS functional, 8.0:1 C/R
Chassis: AW11 MR2
Notes: 4AGZE turbo conversion
