(Originally posted by PioneerX)
Engine Mfg: Vauxhall
Engine Code: Unknown
Cylinders: 4
Displacement (cc): 1800
Rev Limit: Unknown
TPS or MAP: MAP
Boosted or Normally Aspirated: Normally Aspirated
If Boosted- max Pressure (KPa):
Modifications: Twin Dellortos
Chassis:
Notes: "Vauxhall 1.8i 8v (Vauxhall Carlton) - Injection removed - Twin Dellortos - Running MAP sensor."
Vauxhall 1.8i 8v w/ twin Dellortos
- Vauxhall 18SE - 1800 8v.mjlj
- (794 Bytes) Downloaded 1436 times
trigger wheel
Hi what did you use for a trigger wheel on the vauxhall the fitted trigger wheel has 72 teeth ?
cheers
cheers
