Ignition Map?
mikaking
Ignition Map?
Post by mikaking »
Can anyone tell me if the ignition map on a new MJLJ is the same as the one on the ignition map library 'Default ignition Map'. Also what are the 'N' degrees at 'N' rpm of this map?
Yes, when you go to view that forum topic the message is:
"This is the MAP included by default with the MJLJ processor.
It is a 'safe' map that can work for boosted as well as normally aspirated engines."
The quickest way to inspect the map is to load it into the configuration software- you do not need to be connected to the ignition controller to view maps.
