THE RIGHT MEGAJOIT?
fozzie
THE RIGHT MEGAJOIT?
Post by fozzie »
Hi there all you petrol heads,
I'm just about to start my new engine installaion into my caterham i'm removing a crossflow and fitting a 1.8cc zetec with a set of bike carbs gsxr 600 lots of people seem have completed this.
but as soon as i get into the wiring things start to get a little lost
EG MAPS or TPS
If any one has done this or know of a wed site it would be spiffing
Hi Fozzie,
The information you seek can be found under the "How To" section of the site-
Vehicle Installation Guide
http://www.autosportlabs.net/index.php? ... tion_guide
FAQ, covers MAP vs. TPS
http://www.autosportlabs.net/index.php? ... _Questions
Hope this helps.
MartinM
Post by MartinM »
Hi Fozzie
Bike carbs on a Zetec would strongly suggest a TPS solution, Do the GSXR carbs have a TPS on them already? - that would make a very neat install since the Zetec should have the 36-1 teeth set into the flywheel and you can use the existing coilpack, VR sensor and its mounting point. You just need to source an EDIS module and do a bit of wiring and your good to go...
Martin
