Two quick questions...
Does the tach out on the MJ unit give a pulse-per-revolution, or a pulse-per-ignition cycle (o.e. 2 per rev for 4 cyl engine)
Whats the voltage on the tach out pin..?
Looking to drive a LM2917 frequency to voltage chip
Cheers
Pete
Tach Output on MJ
2 per rotation on a 4 cyl 4 stroke... that works out at 33.3333Hz at 1000RPM. I have used the LM2917 in the bargraph section of my DIY rev counter and it works spot on with the MJLJ tach output.
More info on my rev counter here:
http://www.ford-capri.fsnet.co.uk/white ... ounter.htm
http://www.ford-capri.fsnet.co.uk/white ... xt_gen.htm
sorry, to revive this old thread. will the tach output on the MJ be compatible w/ the stock tach lead on the corolla (4age) or will i have to apply the "high-voltage kick back pulse" suggested in the "How To" section under "Installation"?brentp wrote:It's pulse per ignition event. It's a 12V square wave.
