I have the Bosch L-jetronic from an '84 318i and apparently it won't do anything without a certain sort of RPM signal. This signal is the ignition pulse that goes to the coil and also the tachometer. So the only way I could get the engine running with the Mjlj and EDIS was to have the old coil also connected. I tried putting various resistors in place of the coil and it would get the tach working but not the fuel injection. Any ideas on how to get around this? I seem to remember reading that the coil can overheat when it's not connected to any spark plug, and aside from that I've been zapped by it a couple times already
While I was driving around a bit I noticed a few hiccups, like the engine would hesitate and the Mjlj program would momentarily display some absurd RPM reading (143,000RPM woohoo!). Is this more likely to be a VR sensor placement issue? wiring issue? power supply issue? The only source for switched 12V in the engine bay is one 16 gauge wire, is that enough for the EDIS and MJLJ together?
BTW I'm using the v3.2.1 firmware and configurator.
thanks for reading, TJ
