Morning all!
I have a 1957 S1 Land Rover into which I have just installed a 2.5 petrol. It has an LPG system and a high-power coil running through a transistor-assisted ignition system from Maplins.
I do some off-roading but mainly use the LR every day for commuting 25 miles each way to work. When I see water (on or off-road) I tend to get a bit excited and drown the dizzy (and have to wait for it to dry out before continuing)! Hence why I am here now.
By the looks of things, installation won't be too difficult for me, hopefully...
1) Is the rev-limiter part of the kit, or a separate bit to add-on?
2) I like the idea of twin ignition maps, but is the switch and resistor (or whatever it is that's needed) included in the kit?
Thanks for any help, and I'm sure I will be around a lot from now on!!
Hello! Another new member (with some questions)!
- Contact:
Land Rover 1957 S1 88" 2.5 petrol/LPG
