Is it possible to slightly amend the normally aspirated range on the configurator to say 1.1 kPa
Atmospheric pressure in summer can reach 1050 mb / 1.05 kPA and the run time graph at these pressures are off the top of the scale
I agree you can set the boost option in these circumstances but then the resolution of the run time graph is much less.
Steve
Normally aspirated MAP range
