I salvaged two EDIS connectors (after realising the first one's retaining clip was snapped) and kept a stock of pins for that very purpose, though lord knows where I put them when I move house
Simply solder the wire to the pin, drill a hole in the retaining strip, push in the pin and Robert is a male sibling of your ol' girl.
What I've not done yet though, is try and employ this method. Originally the coil -ve lead would run from the points, loop twice through the pickup on the dizzy and then off to the coil. Does the EDIS output loop through the pickp and then connect to earth?
'Case - I've not forgotten your EDIS bits dude
