Very pleased! Kitcar (Ginetta G15) installation (UK)
baxteri
Post by baxteri »
Got EDIS running (after rewiring the VR sensor in the right way round!), switched off, plugged in MJL and strobe gun, works 1st time :) no problems. - Well done Brent!
Engine spec: Mid engine Alfa boxer (Flat 4).
Remember to swap HT leads 2 & 4 for boxer engines as EDIS normally runs 1-3-4-2.
I used EDIS 4 from a Ford Mondeo (£20 from a local scrap dealer in Manchester) - the VR sensor was not the front pulley type as I couldnt find one. It read its pulses from cutouts in the flywheel but I found that making cutouts in my existing front crank pulley works just fine - histerysis control in the EDIS means the sensor works even at a much greater distance from the pulley than is set in the pics at:
http://uk.f2.pg.photos.yahoo.com/ph/ci_ ... .dir=/ad86
Josh_b
Excellent Stuff!!
Post by Josh_b »
i wonder how many of us in the UK have the system up and running now? i have done about 3000 miles with mine now!
Glad to see things working fo
Glad to see things working for you! Your timing wheel setup is very interesting. In fact, I think getting a timing wheel setup is probably the most challenging part of the whole ignition setup.
I've been seeing a lot of orders from UK and Europe in general. In fact, it's comprised 1/2 of my orders as of late!
flashrs1988
up and running not quite ?
Post by flashrs1988 »
Hi josh b, I’m in the prose’s of putting one together, the parts for the controller arrived this morning, have tested the coil and EDIS4 unit all work ok at base 10 degrees advance, take a look at the picks
Cheers
Steve.
http://homepage.ntlworld.com/clark.rs/p ... /jolt1.jpg
http://homepage.ntlworld.com/clark.rs/p ... /jolt2.jpg
