ignition retard?
boostme
ignition retard?
Post by boostme »
I want to use MJLJ on my soon to be turbo car but I need the ability to retard ignition timing will I be able to do this with MJLJ
The MJLJ is a complete, stand
The MJLJ is a complete, stand-alone crank fired ignition system that is fully programmable.
It does not 'retard' ignition per-se, it allows you to fully program the ignition curve.
Since it's a stand alone system, It's not designed to 'piggy back' on existing engine management systems; it controls the ignition system independently.
For perspective, I'm using it on my turbocharged 1985 toytota MR2. I'm running completely stand-alone, using a MJLJ/Megasquirt combination; stock ECU was eliminated.
Also check out the screenshots of the configuration software:
http://picasso.org/mjlj/?q=node/view/7
Hope this helps.
