how far does the map go?
benjamin
Post by benjamin »
ok not usre about this, if my map only goes to 5000rpm and the car car revs to 6000rpm does the megajolt just carry on the 5000rpm values?
same with the map sensor values?
because my car was tuned for 10psi on the dyno as thats all my fuel pump would support, so my map only goes to 10psi. Since iv fitted a new pump i would like to up the boost, im going to retard the timing slightly just to be safe but do i have to add map values on the side? or will the megajolt just continue the 10psi valuse when say i reach 12psi?
thnaks
MartinM
Post by MartinM »
Yep, above the last value - rpm or load (TPS or MAP) - the MJLJ continues to use the ignition advance for that last value..
