downloading filmware
V8Ranger
Post by V8Ranger »
Do I need to download anything into my MJLJ to get it to work?I just finished my MJLJ and I have my engine all wired up.It runs in limp home mode.So now I need to now if I have to download any filmware to it.I have a ford 302 V8 engine and an EDIS8 system.If I have to download anything were do I find it?
The processor you have already has the latest firmware installed. Since you have the MJLJ built, you're ready to wire it into the engine and test it.
You will want to download the configuration software- this is used to tune the ignition map and monitor runtime activity. Download the latest (currently 3.2.1) from the 'How To' section above. http://www.autosportlabs.net/MJLJ_Confi ... n_Software
It's also recommended you use a timing light to verify proper operation. For example, if the configuration software shows you should be at 20 degrees BTDC, the timing light should reflect this.
