MegaJolt and boost
supercharger_1500
MegaJolt and boost
Post by supercharger_1500 »
I searched for turbo and found some threads but I really looking for some simple answers.
Can Megajolt work with forced induction, Is there a document on this? I saw some pictures of a MAP sensors in peoples DIY setups but does the kit some with a 2bar sensor?
I'm going to be running around 7psi and a intercooler on my spitfire 1500 via a mini supercharger. I hear much more boost and the air is heated too much and any advantage is lost.
Any help is most welcome.
Thank you.
rbalmford
Post by rbalmford »
See the Configuring Normally Aspirated or Forced Induction section from http://www.autosportlabs.net/MJLJ_V3_Operation_Guide, can measure up to 21 psi of boost with the standard MAP sensor specified.
More boost = more heat => bigger intercooler to keep the charge temperature down and gain the advantage.
supercharger_1500
Thanks, I will have a look!
supercharger_1500
I should have said it better. I meant more boost more heat from the mini supercharger but I am going to use an ally intercooler which I already have. I printed the document and will have a look.
Cheers
-Ad-
Post by -Ad- »
What willl you be using to control the fuel side of things?
Pressuirised carb(s)?
________
Honda Nh Series Specifications
supercharger_1500
Hello, That's the idea. I have seen someones turbo MG using a carb pre turbo but they had no intercooler which I thought was a little crazy.
Supercharged Nat
Post by Supercharged Nat »
Hi the reason they dont use an intercooler with the carb before the turbo/supercharger is becuase you then have a pipe/ intercooler full of explosive gas ready to go off (its already been heated too!) if the engine backfires/ timing is slighty too advance then youl blow the fron of your car off!
im running a supercahrger on my capri using mjl too, works great! its better than a dizzy ever could be becuase i can dial in some retard at any arp/ boost pressure, but still keep the rest of the timing advanced up for performance!
