rpm bins and max rpm
2002john
Post by 2002john »
Do I need load/rpm bins to max rpm of engine, if advance is same at 5000 rpm as 6500rpm. I have most load/rpm bins down at lower rpm's where most advance is happening.
It's your preference. If you want more granularity in your RPM bins down low you can concentrate your bins at that end. The controller simply uses the last bin when the RPM exceeds that max bin's value.
