TPS spindle adapter - Weber DCOE - any suppliers?
jonboylaw
Post by jonboylaw »
I am wanting to fit an after market TPS to a set of weber Carbs and not wanting to pay a fortune for the Weber item. I have bought a TPS that has a flat sided hole through the body, now I need to source an adapter/extension for the adapter. Does anyone have a supplier or a diagram/drawing that I can use to get some made up ?
I am sure there are lots of you on here that have solved the very same problem.
Oh and also whilst I am at it, and crank sensor bracket designs for a Crossflow would be appreciated (using a Triggerwheel xflow kit that bolts onto the crank with spacers...)
Cheers,
Jonathan
MartinM
Post by MartinM »
No dimensions, but worth looking at
http://www.cate1.co.uk/megajolt/installation.php
jonboylaw
Post by jonboylaw »
Thanks, I had seen this one, but there are no contact details on the page that I could see.
How have other's fitted a TPS? would a Mondeo one fit easier?
Jon
MartinM
Post by MartinM »
jonboylaw wrote:Hi,
Jon
I won't post them here...but you have a PM (or will have in a bit!)
Martin
jonboylaw
Post by jonboylaw »
Thanks Martin,
Much appreciated.
Emerald sell the adapter blanks, they are threaded on one end for the spindle, the other end you need to machine to fit your TPS... these are priced at £3.50 inc VAT and P&P.
Jon
