Need another MJ molex connector
General discussion on Autosport Labs, the mission, website, content, etc.
mariodantas
Post by mariodantas »
Hi fellows.
I'll remake my loom and I'll need a second MJ lite Molex connector with 14 pins.
Can I buy it here separately ?
SIERRA 2.0 DOHC 8V or 16V + Ford EDIS4 + Mejajolt = Happyness.........
Sent PM.
7tastic
Post by 7tastic »
Hi chaps
I need one of these 14 pin plugs too, did you have any luck?
Tony
tony
You can purchase a spare molex and pin set here:
http://www.autosportlabs.com/spare-mole ... -p-47.html
KoolKat
Post by KoolKat »
Regarding your need of a molex connector I can tell you what I just did to get another one. The power supply wiring out of any computer has a 20 pin connector. Just get one of those and with a dremel tool, cut off what is not needed. The wires are already factory soldered and really good quality, just cut off what is not needed and work with the rest. Give it a try and see if it works for you.
Mike Goodwin
1968 E Type with V4 Board
